Lacita
Socket UDP Send not working
11 posts in this topic
I got the problem with this FB. This work:9.PNG
But this doesn't! Its error is 0400, the Input value is out of range(?)7.PNG
This is variable table.
Help me check this. Thank you guys.
Edited by Lacita
How come you use port 60001 and not 6001?
Can you try with 6001, I know the range is up to 65535 but you can give it a try.
Edited by andrei.apopei
Port Number does not matter AFAIK, as long as it's not the common port number used in other TCP/UDP protocol (like port 80) or not being used by another Socket.
I see in your variable tables that you are Initializing some values, such as the Socket definition.
I think, prevent to Initialize the "Handle" value of the Socket. When you are Creating a Socket by the Create FB, you will get a new value assign to that Handle, just as a pointer. This is later on Outputted by the Create FB.
Try checking the current value of the Handle in your Socket. It will not be able to send anything if the value is 0.
I checked that Handle value, it's different from my initial value (= 0), it's 1 as you can see.
But Send FB still not work.
What value should that Handle be? Or what shoul I do now?
I think I'm starting to get what's happening... but you need to try it.
Delete all of the Initial Values set for your Socket variable. In the SktUDPCreate documentation it describes that both SrcAdr and DstAdr sections will be filled with zero once the socket is created. As UDP is an unconnected communication, you don't need to specify any source IP Address.
If the UDPCreate is successful, fill the DstAdr with your target device IPAddress and PortNumber, then try the UDPSend command.
The Handle value is basically just a pointer. If you Create a socket one time in the entire program, it will be filled with 1. If you create another socket, it will have 2 as the handle value. If say socket 1 is closed properly, next time you open a socket it will get 1 as the handle value. So it's predetermined by the CPU.
Oh wow thank you very much innoaloe, it works!!!
This is my setup, hope it will help for anyone have to face this problem.
Edited by Lacita
Good to know that it solved the issue :)
It wish it worked for me. When I bring up _sSOCKET Variable in Watch window Dst Port is set to 0 and Ip is null and I can not modify them either
You need to set up the entire _sSocket variable prior to executing the SktUDPCreate function block.  Notice in the very first post in this thread where the initial value of the Socket variable is set.
Hello people
I'm trying to send data via UTP socket in the SocketTest program, but I haven't been successful yet, below is an image of error 0400 on the send FB
can someone help me with an application example using FB send UTP sending any data and I monitoring this data in any software such socketest for example?
Thanks for read and help
CnGWaCR
Good Morning I am a beginner in PLC programming using the Sysmac Studio software and please help me if you can :-D I'm trying to make an omron NX1P2 PLC read some message via Socket UDP to my PC through the Socket Test program, do you have or know any program with an example application in ladder? thank you
