carga2
FX Series Protocol
4 posts in this topic
Hello, all.
I wrote the communication driver for connecting to the Mitsubishi FX series controllers in C # using the programming port. I searched for this on the Internet and did not find it. Found this here https://github.com/blueskit/MitsubishiPlcProtocol.git, but there is no implementation of the protocol that is used when connecting via the port for programming. This is my first experience in writing such a program. I still have a lot of things to do in my project, in particular, there is no check of the checksum of the received package, well, various checks of the connection, etc. I will be glad if you help me refine it. The program is working, I spread it for those who had the same problem as me. Checked on the controller FX1N. Link to the project http://forums.mrplc.com/index.php?/files/file/1137-mitsubishiplcserialprotocol/&do=download&csrfKey=2dac8b5e4f1405047e19901768de0de9
Edited by carga2
Hello,
I would like to use this protocol through programming port...Is there any description of this protocol?
thanks a lot...
@Jirrr If you need to communicate with FX PLC. I recommend to use MX Component that can use C#, VB.Net to commnicate with FX PLC and have example for coding.
Hello...thanks...unfortunately I need read some data straight to simatic plc(S7-1200) and  only programming port is free (side BD port is already used)...
and that is the reason I need description of protocol on programming port(it is FX2N CPU and ethernet card probably does not exist)....Exists anything like this?....Thanks
