Posted 30 Mar 2018 Hi everyone I'm new to FX5U, 'cause I previously used Q-series PLC. So, is there any possibility to make on delay timer with 1ms PT? Share this post Link to post Share on other sites
Posted 30 Mar 2018 (edited) Yes TON and TOF are available in de FX5 Edited 30 Mar 2018 by Gambit Share this post Link to post Share on other sites
Posted 30 Mar 2018 2 minutes ago, Gambit said: Yes TON and TOF are available in de FX5 Yeah, I know, that they are available, but there are TON with PT 100ms and more, and TON_10 with PT 10 ms and more. And I'm in need of 1 ms time Share this post Link to post Share on other sites
Posted 30 Mar 2018 aha I see. Well in that case can you explain what you want to accomplish. Because at that speed you will also need to make an interrupt program because otherwise you'll be depended on the scan time of the PLC anyway. The fastest timed interrupt in the FX5 is already 1 ms. Share this post Link to post Share on other sites
Posted 30 Mar 2018 i need two pulsating outputs with frequency from 0,5 to 80 Hz. And i set the frequency with TON timer for both outputs something like this /*0.5Gz*/ IF start=TRUE AND vhod1>1000 AND vhod1<1099 THEN timer1(IN:=TRUE, PT:=T#1000ms); END_IF; IF timer1.Q AND vhod1>1000 AND vhod1<1099 THEN out3:=TRUE; out4:=FALSE; timer1(IN:=FALSE); start:=FALSE; END_IF; IF out3=TRUE AND vhod1>1000 AND vhod1<1099 THEN timer2(IN:=TRUE, PT:=T#1000ms); END_IF; IF timer2.Q AND vhod1>1000 AND vhod1<1099 THEN out3:=FALSE; out4:=TRUE; timer2(in:=FALSE); END_IF; IF out4=TRUE AND vhod1>1000 AND vhod1<1099 THEN timer1(IN:=TRUE, PT:=T#1000ms); END_IF; Share this post Link to post Share on other sites
Posted 30 Mar 2018 (edited) Why you can use the PLSY or PWM instruction Edited 30 Mar 2018 by Gambit Share this post Link to post Share on other sites
Posted 30 Mar 2018 i tried, but my program also depends on when out1 and out2 (outputs that pulsating), e.g. If out1=true THEN i'm doing something END_IF With PLSY out1 is always OFF (even when Y1 light is on) or i'm doing something wrong? Share this post Link to post Share on other sites
Posted 2 Apr 2018 sorry for upping this topic again, are there any other suggestions? Share this post Link to post Share on other sites
Posted 3 Apr 2018 Do you use the transistor (MT) or relay (MR) output CPU ? Share this post Link to post Share on other sites
Posted 3 Apr 2018 14 hours ago, Bryll said: Do you use the transistor (MT) or relay (MR) output CPU ? transistor output Share this post Link to post Share on other sites
Posted 4 Apr 2018 You might need to refresh your output when using time sensetive updates. Take a look at the REF and REFP functions Share this post Link to post Share on other sites
Posted 5 Apr 2018 On 4-4-2018 at 7:28 AM, Bryll said: You might need to refresh your output when using time sensetive updates. Take a look at the REF and REFP functions That's exactly why you should use the highspeed instructions like PLSY, PWM etc ..... they work outside of the SCAN Share this post Link to post Share on other sites
Posted 6 Apr 2018 On 2018-04-05 at 2:14 PM, Gambit said: That's exactly why you should use the highspeed instructions like PLSY, PWM etc ..... they work outside of the SCAN Very true, but easy to forget if you try to solve things differently. It normally takes a while before you find the correct instructions. Share this post Link to post Share on other sites
Posted 11 Apr 2018 (edited) Ok. So how do i use PLSY for two outputs, so they do not overlap each other? Like this One idea was to use TIMER_1_FB_M, but I can't put a fractional number, like 6.25ms for 80Hz in timer Edited 11 Apr 2018 by selinrv Share this post Link to post Share on other sites
