asteroide
Micrologix and Sick Inspector?
5 posts in this topic
Hello Friends
I need to control a sick inspector I40 (VSPI) over Ethernet.
I have seen that it is posible with a CompactLogix, but I have a Micrologix 1100 and 1400.
Do you know if is it posible to control with a Micrologix?
Do you have a sample program o documentation about how to do that?
Thanks in advance.
Edited by asteroide
MicroLogix 1100 and 1400 both utilize RSLogix500, an I/O-point development package
All ComactLogix processors utilize RSLogix/Studio 5000, a tag-based development package
Sick Inspector VSPI is an Ethernet/IP-based 2D vision scanner
MicroLogix 1100 supports Ethernet/IP networking for peer-to-peer messaging (explicit CIP messaging with MSG block)
CompactLogix processors communicate via Ethernet/IP utilizing client/server connections
I could not complete the research to verify if the Sick Inspector VSPI supports Modbus TCP over Ethernet.  It appears this vision scanner is Ethernet/IP only; you need a controller that supports Ethernet/IP with implicit messaging.  https://www.rockwellautomation.com/resources/downloads/rockwellautomation/pdf/sales-partners/technology-licensing/eipexp1_2.pdf
The 1100 won't support Modbus TCP and I think only the B version of the 1400 does.
You can do a CIP generic which normally will do want you need.
Thanks for your responses.
According with the user manual:
Micrologix 1100 Ethernet protocols: EtherNet/IP messaging only
Micrologix 1400 Ethernet protocols: EtherNet/IP messaging, DNP3 over IP and Modbus TCP/IP
I have a ML1400 that I could use instead of ML1100.
I have attached an image that is the configuration that I should use with a CompactLogix, according with some tutorials that I have found at internet.
How should I configure it in Micrologix?
How do I select Data-SINT?, service  custom, read, write o what else?
How should I configure all of them?
Could you help me?
Thanks a lot.
Edited by asteroide
This is where Sick's literature will drive your configuration, it is not a Rockwell/Allen-Bradley decision.  I have seen Generic Ethernet module configurations of Type INT or SINT; the hardware manufacturer (Sick) will specify what works for them.  Then you need to know the number of input & output words and the instance numbers.
I found a Sick blog that suggests...Type-SINT, input instance-105, size-124; output instance-100, size-4; Config instance-1, size-0.  In the Connection tab, turn ON Use Unicast Connection Over Ethernet/IP.  http://sickusablog.com/easily-obtain-inspector-vision-sensor-data-ethernetip/
