Posted 13 Mar 2018 (edited) Greetings, so i create project for FX3U in GX Works2. In my program i use function in ST. That function return array with word(signed). I have a warning: Quote No. Result Data Name Class Content Error Code 1 WARNING QueueBySetOn Program compile A WORD/DWORD type label is being used in the return value. The instruction used for the generated code will be changed. When using the designated instruction, use ANY_SIMPLE type except WORD/DWORD type. C9026 ST FOR i_var := 0 TO n_i BY 1 DO TempNumbs := Numbs; TempDevSetsOnPerTime := DevSetsOnPerTime; QueueBySetOn[i_var] := 0; END_FOR; QueueBySetOn[1] := TempNumbs[n_i]; QueueBySetOn[3] := 1; FOR i_var := 0 TO n_i BY 1 DO IF (TempDevSetsOnPerTime[TempNumbs[i_var]] < MaxSetsOnPerTime) THEN QueueBySetOn[0] := TempNumbs[i_var]; QueueBySetOn[3] := 0; EXIT; END_IF; END_FOR; So, it realy funny, GXW cant return int? QueueBySetOn.gxw Edited 13 Mar 2018 by Starsonic Share this post Link to post Share on other sites
