Remon2000i
1747-sn scanner
9 posts in this topic
i am new in plc and i have issue with allen-bradley system image1.jpeg.216b03b025a2cd010a79cc0907d1
processor slc 503 slot 0
scanport slot1 comm led give red flasher no fault an it connected to 1336 plus (vfd).
at scanport dip switch 1&2 on baud rate 57.6
and dip switch at 1336 plus (vfd) i have three switches in remote I/O 1336-GM1  configerd as image2.jpeg.8662bd1cbc715b77d7a1b957b706
SW1: 1 OFF &2: OFF& 3:ON&4:ON&5:ON&6:ON&7:ON&8:OFF
SW2:  1:ON &2:OFF&3:ON&4:ON&5:ON&6:ON&7:OFF&8:OFF
SW3   1:OFF&2:ON&3:ON&4:ON&5:OFF&6:OFF&7:OFF:8:OFF
JUMPER J2 BETWEEN 1AND 2
at scanport terminal resistor 150 ohm
HOW I CAN MAKE SCANPORT COMMUNICATE WITH VFD 1336 PLUS ?
Is this something that has been running and now doesn't?
Is this a new install, an upgrade, etc.
What lead to this issue?
1- yes before I had  fault inside vfd serial fault (10) and I found in side vfd 3 IGBT was burn and I changed it now it working ok .
Thanks
It's very likely that whatever happened to the drive to destroy its IGBT transistors also damaged the 1336-GM1 interface board.
If there are other RIO devices on the daisy-chain network, then you can check the status bits for the 1747-SN scanner module to see if those are working correctly.
Otherwise the probable answer is to replace the 1336-GM1 interface board.    While these have not been manufactured for many years, they may be available as replacement parts from Rockwell or on the aftermarket.
1 person likes this
Thanks for your reply in the site I have anew card from scanner and I replaced it and also not working .
I searche about 1336GM1 board and i found it on eBay site but I have doubt on it because some board written on public used .
no any  way to can assure from problem from this board ?
when I search about this problem I found this sheet .
caedf201-0bc5-44d5-9e48-a1cf0a549077.MP4
1215444485.pdf
Edited by Remon2000i
Sorry this Vedio not related for our conv:-)ersation
dear ken roach i found in our store anew card from 1336gm1 and i replaced it but the same issue .
what is your advice for my status ? how i can check the problem ?
thanks
best regards .
Is this the only device it's talking to??? As Ken noted if its talking to the other devices, then it's your drive.
