Posted 14 Feb 2018 Hi all im trying to set up a powerflex 525, ive downloaded ccw. i plug the usb into the 525 and into the computer and nothing happens i expect to see an autoplay dialog box appear if i browse to the drive and select it there's a long wait before it says its not responding this is a brand new drive any help will be much appreciated Share this post Link to post Share on other sites
Posted 14 Feb 2018 Read the Word document attached to Knowledgebase Article 531941 (Access Everyone). Share this post Link to post Share on other sites
Posted 14 Feb 2018 hi thanks for the reply but i click your link its no longer there? Share this post Link to post Share on other sites
Posted 14 Feb 2018 The link worked for me. I think you will need to set up a KnowledgeBase account (free) to view the article. Here is a direct link to the Word document in case that works better for you: https://rockwellautomation.custhelp.com/ci/fattach/get/867658/0/filename/Mains+free+and+pf5+importexport.docx Share this post Link to post Share on other sites
Posted 14 Feb 2018 (edited) Thanks ScottC joe but this still hasnt solved my issue as soon as i plug the usb into the laptop nothing responds ive change one of my hards drives from E to H as the doc says that itll use E thought there may be a conflict but no its still the same?? i really appreciate the doc scott and joe but ive been doing that to the word Edited 14 Feb 2018 by GL3NN Share this post Link to post Share on other sites
Posted 14 Feb 2018 Does the unit show up as an external drive in Windows Explorer? Share this post Link to post Share on other sites
Posted 14 Feb 2018 (edited) yes it is as a usb drive if i click it or right click it it says system not responding after a min or 2 iv recently downloaded ccw micro800 controller 10.01 is this the problem? im running a win 10 64 bit os but the download said that it could handle that the links below https://www.rockwellautomation.com/global/support/connected-components/workbench.page#/tab4 Edited 14 Feb 2018 by GL3NN Share this post Link to post Share on other sites
Posted 14 Feb 2018 (edited) Here's the recomended requirements to run CCW Processor Intel Pentium 4 2.8GHz or equivalent Intel Core i5 2.4GHz or equivalent RAM Memory 2 GB 8 GB or more Hard Disk Space 10 GB free 10 GB free or more Optical Drive DVD-ROM Pointing Device Any Microsoft Windows®-compatible pointing device and im running intel core I3 7th gen cpu @ 2.4GHz 12Gb RAM 1T hard drive 800GB space left do you think this is the issue? Edited 14 Feb 2018 by GL3NN Share this post Link to post Share on other sites
Posted 14 Feb 2018 Probably not. I happen to have a 525 that I need to configure, so I popped off the control module and plugged it into my PC. It showed up as a removable drive. The executable runs but shows "Disconnected". I connected it to my VM that has CCW installed and it looks like it works. The executable opens and uploads the parameter file as a *.pf5 file. This file can't be edited as far as I know. I'm experimenting with CCW now to see if I can configure it offline. Share this post Link to post Share on other sites
Posted 14 Feb 2018 cheers Joe the thing is i cant get as far as it saying disconnected i wonder if i could set the IP address manually then get to it via ccw software by clicking discover or see if linx finds it?? Share this post Link to post Share on other sites
Posted 14 Feb 2018 hi joe i really appreciate all your help but my trick worked entering the IP and sub net address manually then discovering it in CCW 1 person likes this Share this post Link to post Share on other sites
Posted 14 Feb 2018 I assume you have the drive powered up, right? If that's the case, your trick is what I almost always do, except almost all of the 525s I've personally worked on have been integrated into a Logix 5000 project. I just set the IP address from the HIM and let Logix do the rest. This is only the second one I've done as a stand-alone machine in CCW. Share this post Link to post Share on other sites
