Posted 21 Dec 2017 I have Omron PLC controller and I try to write and read from it by using USB port in C#. I have no idea how can I do it I tried it for some days. I succeed read and write by rs232 port and I need help for doing it using USB. Thanks. Share this post Link to post Share on other sites
Posted 21 Dec 2017 To the best of my knowledge, the USB port on the PLC is for programming only. Omron tools like CX Programmer, CX Integrator, etc... Share this post Link to post Share on other sites
Posted 21 Dec 2017 What Omron controller are you using? As IO_Rack has indicated, the USB port on most Omron controllers are for programming only. Regards, Garry Share this post Link to post Share on other sites
Posted 21 Dec 2017 17 minutes ago, gclshortt said: What Omron controller are you using? As IO_Rack has indicated, the USB port on most Omron controllers are for programming only. Regards, Garry I am using CJ1W-PA202 I am programmer and try to read and write to it using C# Share this post Link to post Share on other sites
Posted 21 Dec 2017 32 minutes ago, IO_Rack said: To the best of my knowledge, the USB port on the PLC is for programming only. Omron tools like CX Programmer, CX Integrator, etc... I know How to do it using C# by rs232 port but, It's not work using USB port Share this post Link to post Share on other sites
Posted 21 Dec 2017 The CJ1W-PA202 is the power supply. Is this the CJ1M? If so it has a Built-in peripheral port: Programming Device (including Programming Console) connections, Host Links, NT Links Built-in RS232C port: Programming Device (excluding Programming Console) connections, Host Links, no-protocol communications, NT Links, Serial Gateway (Compoway/F master) Garry Share this post Link to post Share on other sites
