abdullah eraslan
array and string
7 posts in this topic
hi all
I do not know why arrays and strings are used in plc programming. Where are they used in the application?
String is very useful if you want to send character from PLC to be display to the HMI.
In small application you don’t need an array, but for larger application array is great option, especially when you want represent multiples values in single variables.  Example in data block an array of [1..30] real - Temperature.  So instead of writing individually to access all those 30 temperature value, just do it in an array to save time, space and easy to remember during your programming.
can you give me specific example.I did not understand your example.
an example is barcode scanner that reads label and sends you back the string.
another example is if you want to print label, printer will need information in a form of a string.
pleasea give an example in industrial automation
That IS an example in industrial automation. Anything automotive will have label (every component). Another examples would include logging data, part tracking using RFID tags, setting drive parameters, getting data from scale or flow meter or vision system or ECU and many more.
What kind of automation you do?
We are using a lot of strings in arrays.
There where you talk about customer name, adres, settings etc.
If you use this in the PLC in stead of in the HMI, this give a lot more possibility in case of sorting and logging settings in the plc memory.
an "tekstlist in an HMI solution" is to static for doing this.
