riandanualdy
cant connect HMI omron to PLC omron [solved]
4 posts in this topic
halo, i'm newbie in HMI and PLC.
i have a problem connect HMI omron NB7W-TW00B TO PLC OMRON CP1E.
i done setting same baudrate,data bit,parity check, and stop bit in HMI and PLC
and i use nb designer for create a HMI display.
and this is attachment: a cx programmer, bit switch and bit lamp in nb designer.
and the output in hmi is [2]PLC No Response:00-00-1
can you help me? thanks
Edited by riandanualdy
https://www.myomron.com/index.php?action=kb&article=1536
The above thread will walk you though connecting your HMI to the PLC.
1. Connecting Method
2. Wiring diagram
3. HMI Attribute settings
4. PLC Attribute and PLC settings
5. Example program
Make sure that the units are communicating by the indication light on the PLC.
Hope this helps you out.
Regards,
Garry
2. Wiring diagram
5. Example program
Regards,
Garry
its working thank you garry.
Have a nice day
2] PLC No Response:00-00-1 pop up display in plc please solve this problem sir...
