asad heidarloo
Conection FX2N-1PG & MR-J2S
16 posts in this topic
Hello to all
I have a FX2N-32MR-001 PLC which is connected to a FX2N-1PG.
The FX2N-1PG  is connected to a MR-J2S Servo.
The backup battery's PLC has finished and its program has been erased. Now, when I download the application into the PLC, the connection between the FX2N-1PG card and the MR-J2S Servo Drive is not included.
Please help me.
What do you mean is not included ? The 1PG is driven from the PLC program
What lights are lit on the 1PG?
As Gambit says - the plc program should have some TO and FROM instructions in the program
Can you post the plc program here.
I have backup from my plcs program .
all of program is true and worked but communication between 1pg & mr-j2s is not true.
mr-j2s does not command and does not move
Most likely you need to home the system First
i have not any wiring detail.
This manual is quite descriptive there is a troubleshoot section toward the end.
Manual
Steve
Manual
Steve
thanks
i have this manual. but i don't understand where is Problem.
9 hours ago, shaikhasim said:
USE THIS WIRING FOR REFRENCE
thanks mr.shaikhasim
I do not think wiring is a problem. becauce i did not change it.  The backup battery's PLC has finished and its program has been erased. Now, when I download the application into the PLC, the connection between the FX2N-1PG card and the MR-J2S Servo Drive is not possible
ENTER JOG SOME  VALUE  IN DATA REG. IN D307 & D407 ( EXAMPLE  100 IN D307 AND 100 IN D407)
AFTER ENTERING TRY TO ENERGIES COIL M704 FOR FWD ROTATION AND M705 FOR REV ROTATION
FOR POSITION TRY TO ENERGIES M708 COIL
ALSO MONITOR D329 ERROR DATA REGISTOR
IF ANY ERROR OCCUR LET ME KNOW.
I HAVE MODIFY YOUR PROGRAM SO TRANSFER WHOLE PROGRAM WITH DEVICE BATCH IN TO PLC  AND THEN RUN AS PER INSTRUCTION.
Hamnosh-fx2n-32mt-eslive3 MODIFY.rar
