Milosh
Change title bar of pop-up screen
Hi all,
Is there any way to change title bar settings for pop-up screen like font, close screen icon etc?
Thanks in advance,
Miloš
Not that I have seen.
Close button on title bar is all grayed, and like that, is not have good visibility.
I hope that I can change it to standard red button with white X.
For your Pop Up screen, check "No Title Bar".
Create your own title bar using a standard rectangle or text box if you wish to have text and place it at the top of your Pop Up screen.
Create a graphical white "X" with a red background in Microsoft Paint.
Now, use a Command Button to put in place of where the "X" should be.
Set the Command Button to:  Function - Control Pop-up Screen. Action: Close Local Pop-up Screen. From the Color/Shape tab, Shape from, choose Bitmap.
Then from Select Shape 1, browse to the bitmap you created in Microsoft Paint.
The built in features can not satisfy everyone but Omron's NS does offer the flexibility to work around. I've done this.
Thanks for reply.
Yes, that is one solution, but in that case I don't have posibility to move pop-up screen around the base screen.
8 hours ago, Milosh said:
Thanks for reply.
You are correct.
Instead of using a Rectangle or Text Box for your title bar, use a Command Button. Set it to:  Function - Control Pop-up Screen. Action: Move Local Pop-up Screen.
