Posted 16 Nov 2017 Hello, Is there a way to limit the input of an ingredient value, possibly by use of an Enum? For example, I have an ingredient called Press_Speed. I want the values to be either Normal, Slow_1x, Slow_2x, or Slow_3x. On the PLC these values are interpreted as numbers. Can I limit the input to the String representation of the Enum? I'm using the NA series HMI with Sysmac Studio. Share this post Link to post Share on other sites
Posted 16 Nov 2017 You can set min a max value for each ingredients in recipice when you add ingredients. For example min 0 and max 100. Than you are not able to set value which is out of range. Share this post Link to post Share on other sites
Posted 16 Nov 2017 That has more to do with data validation which is different. In the same way that a Boolean data type will give you the option of a different keypad with the options True and False buttons, I'm looking for a way to allow users to select the Enumerated values, with the ability to enter its String representation on the keypad (Normal, Slow etc), not its numerical value (1,2, etc). Digging into this, it appears there's no way to accomplish this. Share this post Link to post Share on other sites
Posted 16 Nov 2017 2 hours ago, gunnaraherman said: Digging into this, it appears there's no way to accomplish this. You can do this, perhaps not with the canned recipe tool, but by building your own recipe handling code. I typically build my own recipe code anyway as it is much more flexible. Share this post Link to post Share on other sites
Posted 16 Nov 2017 Up until now, the canned recipe control has worked well for me, although now that my needs have changed, I may need something a little more versatile. Do you have an example of a custom built, more flexible recipe editor? Share this post Link to post Share on other sites
Posted 16 Nov 2017 Just use a button to turn on a momentary bit and select the numbers in the PLC. When the bit is on use it to show which speed is selected on the screen. To change numbers in the PLC use a number box and put a password on it. Or you could use a string into a DM area in the PLC - they enter the words - push a button and use a table compare function or something in the PLC to determine what has been typed in - match - turn a bit on. Share this post Link to post Share on other sites
Posted 16 Nov 2017 Here is an example of some simple recipe code, of course this can be much more elegant than this: Recipe Sample.smc2 Share this post Link to post Share on other sites
Posted 22 Nov 2017 Apologies for the late response. I was traveling. Thanks for the example. I'll need to update Sysmac Studio first to view it, but I'm sure it'll shed light on this issue and future issues. In the meantime, I was able to create an ingredient that was uneditable and not visible within the recipe viewer object, and map the variable to a group of radio buttons. The only thing extra I needed to do was call the VB function to set the recipe ingredient before I saved the recipe. Thanks for everyone's help. Share this post Link to post Share on other sites
