blewl
OMRON PLC with Modbus TCP/IP
4 posts in this topic
Hello
Has anyone got an Omron PLC running with Modbus TCP/IP?
If so was it difficult?
Thanks!
Which model?
And why didn't you put this in the Omron forum?  You are more likely to get responses there.  I can move it if you'd like.
I've used couple times the CP1W-MODTCP adapter board with CP1H. It can be a master or a slave, and supports read and write commands, but not the combined read/write command.
I have a CS1H that I recently had to get modbus TCP/IP comms to.
Omron has some ready made function blocks and without too much effort they worked. I had to ask the Omron help line guys for them though.
Specifically ..
An MTCP_ETN_Connect Block (To set the Connection Adress)
an MTCP_ETN_Fn06 Block (To Write)
and an MTCP_ETN_Fn03 Block (To Read)
