NgoHoang
Pointer In GX-Work2
9 posts in this topic
Dear all!
Last time,I never use Pointer type in GX-Work2. I use ST languge.
I define a variable in picture below.
Can you help me:
    - I want to move a value to P100 (P100 is a Pointer).
    - If M0 is TRUE, D memory = P100 will be set K100.
 I search something in Internet but can not see. Any doucument about pointer in PLC Mitsubishi (ST), please send it to me.
Thanks and best regard
Not sure what you want to accomplish since P100 is a pointer (as you also say yourself). No matter if you use Ladder or ST, pointers are used for referencing other program parts, and sequence control, not to contain "values". What is it you want to do?
You need to use data registers (D) not pointers (P).  Pointers are to jump to different parts of a program.  They don't store data.
If you are hoping to use it like an index pointer those are Z.
MOV K10 Z1
MOV D0Z1 D1000   :: Will move D0(+10)=D10 > D1000
Thanks all!
My mean is same with WattUp. Sorry because I describe not clearly!
Last time, I want o access D"a" memory. But "a" = Dxxx + 100.
Now I understanded. Z is Dxxx. Index pointer Z is correct!
Thank you so much!
Edited by NgoHoang
If you don't want to use devices like Z create an Array variable then you can use ArrayName[pointer]
Thank for your reply!
We can use D0Z0 := K100 but if D0 is named is Data, we can not use "DataZ0". Any more ideas about it?
Thanks and best regrard!
As in my previous post create an array called Arrayname[pointer]
In your case DATA[Z0] or DATA[labelname]
Here is an example Array.gxw
Edited by Gambit
