Posted 10 Nov 2017 (edited) Hi guys, Do you have experience or know any good guides to set up a simulation case like this: - Simulating a PLC program such that the "PLC" is accessible on the Ethernet (for example just locally). - In addition, setting up the PLC settings with FINS protocol such that it is possible to write to the PLC with FINS protocol from another device. The first part is most important. Best regards PC_VS_PLC Edited 10 Nov 2017 by PC_VS_PLC Adding more tags Share this post Link to post Share on other sites
Posted 10 Nov 2017 The above threads may help you out. Regards, Garry Share this post Link to post Share on other sites
Posted 28 Nov 2017 On 11/10/2017 at 4:08 PM, gclshortt said: I ended up using a real PLC. It was too time consuming to find a way to talk with the simulated PLC with a external script. The above threads may help you out. Regards, Garry Thank you for the reply Garry. And yes, your guess is right. I have a Python script that will try to read and write data to and from the PLC. I was hoping that someone had set up the cx-simulator with a PLC program for FINS communication and actually made it work writing and reading to the specified FINS node. Share this post Link to post Share on other sites
