marcinmrag
edit time variable in Recipe NA HMI
4 posts in this topic
Hello,
I would like to use one recipe parameter which is time variable. But I have problem to use time variable in HMI recipie. Can someone help me with this? How i can handle this? I can put value in INT but how can i convert it to TIME in PLC program?
Look for NanoSecondToTime, or MillisecondsToTime instruction in NJ. You put LINT valeus of Timespan in Nanoseconds / Milliseconds in HMI then convert it to time by program.
If your time requires Hour, Minutes, Seconds, you can put each individually then calculate the total value in Nanosecs / Millisecs before converting to Time.
Alternatively you can implement a Custom Time Keypad in NA to input Time values directly to Time variables, although it's more complicated (requires VB Scripting)
@innoaloe
Do you have an example of using the custom time keypad to edit the time variables directly?
This would be very much appreciated.
