Posted 24 Oct 2017 Hi I have a pv 600 display. I had the problem 32 error. That is real time clock test error . I change the dalllas but the problem still retain and my application also corrupted. i ill update the firmware but the fault remains the same. how to rectify it? what is the solution for the prblm? Share this post Link to post Share on other sites
Posted 24 Oct 2017 Look at this manual:http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2711-um014_-en-p.pdf It doesn't give a lot of information but the following knowledgebase article (access level: TechConnect) is better: https://rockwellautomation.custhelp.com/app/answers/detail/a_id/61280/page/2 Basically, it says to replace the RTC battery. This article (access level: Everyone) talks about the batteries: https://rockwellautomation.custhelp.com/app/answers/detail/a_id/14826 Share this post Link to post Share on other sites
Posted 26 Oct 2017 Thank u for the reply, I find the solution i changed dallas DS9034pcx. It worked out. Thank u once again. Share this post Link to post Share on other sites
Posted 1 Nov 2017 hello I have another problem in pv 600. When i download the program using panel builder 32 i had an error that showing Error 4003: Terminal destination memory error and in my display it shown file write access error. I cant able to download the program. what can i do to rectify the problem? Share this post Link to post Share on other sites
Posted 1 Nov 2017 Was this a working PanelView prior to attempting download? Have you gone through the PanelView troubleshooting to verify the hardware is functioning properly? Is this a PanelView 600 or a PanelView Plus 600? Refer to the manual and verify the status lights on power-up. http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2711-um014_-en-p.pdf Share this post Link to post Share on other sites
Posted 5 Feb 2018 hello I had another problem in pv 600 it shown 31 error. I read the manual that is stuck touch. I remove the touch and again it showing 31 error and i also change the new touch it again showing 31 error. how to solve the problem. Pls help me. Share this post Link to post Share on other sites
Posted 5 Feb 2018 (edited) Error "31" is a "Stuck Key Test" Does you unit have a keypad? Quote 31 Stuck key test What is the complete catalog number of your PV? Edited 5 Feb 2018 by Mickey Share this post Link to post Share on other sites
Posted 5 Feb 2018 AB CAT 2711-T6C5L1 SER B REV F FRN 4.46 this is my panel view catalog number. Share this post Link to post Share on other sites
Posted 5 Feb 2018 Looks like time to replace the screen. Not sure where you would get one though. Share this post Link to post Share on other sites
Posted 6 Feb 2018 When you say "I remove the touch and again it showing", please describe your actions in more detail. You disassembled, removed the touchscreen membrane, and powered up without? A PanelView Standard/Classic diagnostic code 31, stuck key, will keep the unit from powering up and going into run mode. There is no way around this diagnostic code...either the touch ribbon cable, touchscreen or mainboard has failed. This was a popular series. There are many new and used units on the market. https://www.amazon.com/Allen-Bradley-2711-T6C5L1-Panelview-600/dp/B00TT5J5US Share this post Link to post Share on other sites
