Posted 23 Oct 2017 (edited) Hi every one I have a wire -O machine from Renz (Autobind 500HS) with Got1000 HMI when I turn on the machine I see the Renz Logo on the screen which is ok but seconds after, the screen shows the message" system check ok! instead of going to the machine's main menu.please let me know what the problem could be. second question.If I power up this HMI (which was working before)without connecting to the PLC, what should I see on the screen?does it go to the main menu? Thanks a lot helping me Edited 23 Oct 2017 by soheil misspeling Share this post Link to post Share on other sites
Posted 23 Oct 2017 You should connect with developer of the system. Share this post Link to post Share on other sites
Posted 24 Oct 2017 Thanks for the reply please let me know more information.what is developer of the system? Share this post Link to post Share on other sites
Posted 24 Oct 2017 3 hours ago, soheil said: what is developer of the system? 18 hours ago, soheil said: I have a machine from Renz (Autobind 500HS) I.e. the answer is obvious. Share this post Link to post Share on other sites
Posted 31 Oct 2017 The answer is not obvious, or he wouldn't be asking for help, would he? Try and be a bit more friendly to those who're asking as this forum has helped me loads recently! To original poster, have you got back ups of the HMI program? Have you got the ability to link to it using GT Designer software? When you power up, it should load to whatever base screen was set by whoever designed the program for it. Usually a main menu screen, yes. Share this post Link to post Share on other sites
Posted 31 Oct 2017 Actually the developer of the system was obvious. He stated it was RENZ. Share this post Link to post Share on other sites
Posted 1 Nov 2017 Thanks a lot for your reply. The problem solved .it was the connection Cable between Plc And Got 1000 (Rs422)one of the wire was disconnected. The correct function is as follow: when the machine is switched on the screen shoes the RENS logo for 5 seconds then goes to the next stage showing the operating menu.If the connection between plc and screen is lost (faulty cable) then at the first stage, screen shows RENZ Logo then the message "PC CHECK OK !" appears on the screen after 15 seconds. Share this post Link to post Share on other sites
