Riff
Fins communication NX1P2
2 posts in this topic
Hi.
I have a NX1P2 and need to communicate with another system over fins.
I have set local network to 1 in "Controller setup -> Operation settings -> Fins settings"
In "Ethernet/Ip port settings -> Fins settings" I have only what is setup as default.
In Global variables I have a bool with %w1.00
Is there anything else that needs to be setup at my end?
Kurt
If you're using FINS/UDP then no. If you're using FINS/TCP however, you need to setup Client/Server IP that will be connected to the NX1P2
