Posted 25 Sep 2017 Where would I find TC_2PID_Function_BLOCK? as described in the Temperature Regulation Solution, Quick Start Guide v1.02 Is there somewhere on the omron web site to find all up to date FB Libraries? Share this post Link to post Share on other sites
Posted 26 Sep 2017 Chances are if it's a function block made by Omron, it's already in your software install directory. You just need to import it into the project. File menu, Function Block, then Load Function Block from File. Check in C:\Program Files(x86)\Omron\CX-One\Lib\FBL Share this post Link to post Share on other sites
Posted 26 Sep 2017 1 hour ago, Crossbow said: Chances are if it's a function block made by Omron, it's already in your software install directory. You just need to import it into the project. File menu, Function Block, then Load Function Block from File. Check in C:\Program Files(x86)\Omron\CX-One\Lib\FBL Thanks Crossbow, been there. Omron feild service engineer was kind enough to send it over, when I asked on myomron knowlagebase. looks like a great way to control temp using a PLC & thermocouple card. Share this post Link to post Share on other sites
Posted 22 Sep 2018 On 9/26/2017 at 4:12 AM, printengineer said: Thanks Crossbow, been there. Omron feild service engineer was kind enough to send it over, when I asked on myomron knowlagebase. looks like a great way to control temp using a PLC & thermocouple card. Hi printengineer, I also have problem when control temperature using PLC Omron, could you please help and send me TC_2PID_Function_BLOCK. my email: toan1003@gmail.com. Thanks a lots. Share this post Link to post Share on other sites
