NgoHoang
Bit Transfer
10 posts in this topic
Dear all!
Could you tell me, how to move amount bit anywhere of D1 to anywhere of D2 in PLC Mitsubishi?
I read in manual SH(NA)-080809 but I not yet found.
Thanks and best regard!
Edited by NgoHoang
ROR(P)
RCR(P)
Just now, Gambit said:
ROR(P)
RCR(P)
Thanks for yor reply!
But my mean is difference: I want to copy 3 bits of D0 ( ex: bit 10 to bit 12) to 3 bit of D1 (bit 2 to bit 4) and another bits of D1 is not change!
Well the easiest would than probably be to  use the bit notation of the word adres   D0.A, D0.B and D0.C
Gambit is correct. There is no instruction that will get three random bits in one word to transfer to another. The best would be using the Kn designation to move 4bits (minimum, 32 bits maximum at 4bit increments) at a time.
Thanks all!
I'm looking for a command same with this command in PLC Omron.
If you know it in Mitsubishi, pls post it on the topic
Thanks
Edited by NgoHoang
Add new image
First: It's very hard to help if you cannot explain what the purpose is. Why do you want to do exactly this?
Second: To solve your problem, use a combination of the answers you have already received, and the easiest is probably @Gambit's bit notation when you only have two or three bits. If not, then again please explain what you want to accomplish then it's easier to help you with the most elegant solution.
Thanks for your reply!
I make a example:
In some case, PLC receive data 2 word D0 and D1 as below image. I want to merge Data 1 and Data 2 to 1 Word (example D2).
Could you tell me the best simple way to do this in PLC Mitsubishi (Last time I do this with Omron is very easy)?
You should look at:
DIS(P) 4-bit dissociation of 16-bit data
UNI(P) 4-bit linking of 16-bit data
WTOB(P), BTOW(P) Data dissociation in byte units, data linking in byte units
1 hour ago, Gambit said:
You should look at:
Dear!
DIS, UNI, WTOB, BTOW also can not correct for this matter.
So, I can do it by WAND, WOR....with data before merge it.
Thanks all
