Posted 7 Sep 2017 I need to connect a analog amplifier with the analog input 0-10V on my Siemens 1200 PLC (located inside the same cabinet as plc, about 40 cm between). do i need a shelded cable? or just RK0,75mm2? do i use any special color on 0-10V? Share this post Link to post Share on other sites
Posted 26 Sep 2017 I wouldn't think it was necessary to use shielded cable for that length unless there is a great deal of High voltage 3 phase or such right on top of it. Most Companies use BLUE for DC+ wiring some also use it for the negative side but many use grey. I wouldn't use black outside of a shielded cable because alot of companies use black for H1 [incoming L1 from outside the panel to the breakers and such]. Share this post Link to post Share on other sites
Posted 17 Dec 2017 (edited) If you don't use screening you can always twist the two cables tightly together. It helps minimise pickup. Obviously not as good as full screening though. Edited 17 Dec 2017 by whyme Clarrification Share this post Link to post Share on other sites
Posted 19 Dec 2017 I am sure you get away with not using shielded wiring. But why??? Share this post Link to post Share on other sites
Posted 19 Dec 2017 Never Have used it inside a panel. Share this post Link to post Share on other sites
Posted 2 Jan 2018 Thanks for all the answers, please keep the shielded debate open ^^ Share this post Link to post Share on other sites
