Posted 7 Sep 2017 i'm working with vijeo designer and i have a problem with popup windows. I'm trying to make a popup window appear with a variable. A bool to be exact. I want that a popup window appears when the bool becomes 1. But so far i haven't found a way to do that. Can someone help how I could do that? It's the meaning that that bool becomes 1 when there is an error and that the popup window appears then to let the user know there is an error. Or does annyone have a better idea? Share this post Link to post Share on other sites
Posted 8 Sep 2017 Hi wouter94, You can use text display to warning error. Share this post Link to post Share on other sites
Posted 8 Sep 2017 yes, but I find that pretty annoying because when you want to make changes to the panel you have to move al those text displays to the side. And the same message has to appear on every panel and i have 19 panels. So if i could do it with a popup window I just have to make 1 Share this post Link to post Share on other sites
Posted 8 Sep 2017 You will have to use actions. Create a new conditional action and tell it which popup to open or close Share this post Link to post Share on other sites
