NgoHoang
MELSEC Communication
8 posts in this topic
Dear!
Could you tell me how send data from PLC Mitsu Q03UDV CPU to another Q03UDV CPU use MELSEC Communication Protocol with Ethernet built-in port?
- Config for 2 CPU as picture below  (use same Port) is correct or not? Need to config more parameter?
- Which command I can you to send a data?
- Melsec Communication Protocol send and receive at the same time, right?
Thanks and best regard!
If you have 1 sample program (simple) or a topic about this, please send it to me.
Dear All!
Can you help me review my software below 2 program of 2 PLC Q-Series:
When I On bit M1000 to Open Port of another PLC, M1003 (Error flag) is set.
I don't know why, Could you tell me that reason?
Sorry, because I'm new one but the job is very urgent. Tomorrow, I use MC Protocol but can not run. These are program for Socket TCP.
@kaare_t
TCP_CPU1.gxw
TCP_CPU2.gxw
Edited by NgoHoang
I have attached a program I used to send data between 2 Q series over Ethernet. Take a look as see if that helps.
EthernetLink.gxw
Thanks alot for your reply @WattUp!
Could you tell me, command GP.READ and GP.WRITE is use for MC Protocol, right?
Because I see in the Ethernet Built-In CPU, you define MC Protocol and in Network Parameter, you define another network. Can you help me explain about this.
Sorry for the question because I studying about this network.
This program is using an EJ71 Ethernet card to handle the communication. When I did this using the built-in ports I had issues with Ethernet timeouts.
My Mits rep told me that the CPU prioritizes itself over networking and I have had no such issues since using the EJ71 so i guess I believe him.
The built in port is talking to a GOT1000 via MC Protocol. That is why you see that there.
Edited by WattUp
More info
Thanks WattUp!
Your explain is very helpful for me.
If you have any project demo for MC Protocol to transfer data with 2 PLC, please send it to me.
Thank you alot.
Affer research some infomation, now I can communicate 2 PLC use TCP/IP and UDP/IP.
Thanks all.
But now, I don't know how to create this command (in the yellow circle)?
hi ,
need to finish that command  I----------[ MCR   N0 ]-I
after that , that structure in yellow circle will created itself.(after download to plc)
