Posted 12 Jul 2017 hi actually i have never tried plc to encoder programming , i have the FX3S-30M plc with encoder ,can someone help me programming the encoder to have better understanding . Thanks Aakash Share this post Link to post Share on other sites
Posted 12 Jul 2017 (edited) I take it you mean Encoder to -> plc What do you want to know? Where to connect? What counters to use? etc Edited 12 Jul 2017 by Ron_S Share this post Link to post Share on other sites
Posted 12 Jul 2017 (edited) i want to know where to connect ,what counter can i use. I want it to program for 0 to 360 ,also can i know the direction of rotation . encoder -TVI50N-09BK5A6TN-00360 Edited 12 Jul 2017 by aakash Share this post Link to post Share on other sites
Posted 13 Jul 2017 (edited) Hello,You can read in the FX3S manual for high speed counters. There is a detailed description of one-phase and two-phase counters. The encoder is connected to the first digital inputs from PLC that are fast.Sincerely,K. Raykov Edited 13 Jul 2017 by kraykov Share this post Link to post Share on other sites
Posted 13 Jul 2017 hi i have seen there was no mention i am looking at wrong manual.you have the link for the same Share this post Link to post Share on other sites
Posted 13 Jul 2017 Hi aakash, Here's a link to the guide http://dl.mitsubishielectric.com/dl/fa/document/manual/plc_fx/jy997d16601/jy997d16601q.pdf The best regards, K.Raykov Share this post Link to post Share on other sites
Posted 15 Jul 2017 hi ,thanks for the help i was just programming it i had problem.At wiring do the input X0 ,X1 of plc can be either source or sink type.The encoder will give pulses , do i have to make any changes or i can just it either way Share this post Link to post Share on other sites
Posted 16 Jul 2017 Hi aakash, the specification encoder is with a push-pull output and inputs x0 and x1 is not a problem to be on a source or sink circuit. When connected to a source circuit A signal - black cable connecting to X0, B signal - white cable connecting to X1 and brown cable 24VDC, blue cable 0VDC to a power supply. The best regards, K.Raykov Share this post Link to post Share on other sites
Posted 17 Jul 2017 Hi thanks i tried that with already used c251 2phase 2 count. Not sure the use of 1 phase 1 count ,2 count they have the same connection to plc i have to connect both A and B phase. Share this post Link to post Share on other sites
Posted 17 Jul 2017 Hi aakash, what use will this encoder use for? This will be decisive for choosing a single-phase counter with one input, one phase with two inputs or two-phase with two inputs for the A and B series. The best regards, K.Raykov Share this post Link to post Share on other sites
Posted 17 Jul 2017 hi actually this was for practice only to learn then i can use when i need .i like to know the difference between them thanks Share this post Link to post Share on other sites
