zbyszek54
WireShark capture of PC <-> Omron NJ via CIP protocol
26 posts in this topic
I see... In that case I'm not sure. Never tried that before in NJ/NX.
Manual W506 (NJ/NX Ethernet/IP Port) doesn't mention whether that is possible or not.
By the FINS/UDP I mentioned before, what I meant is using a direct FINS protocol. So not FINS over Ethernet/IP.
This is possible even in NJ/NX. You can use the "Multiiway" tool to test it. No Ethernet/IP encapsulation is not needed.
