Posted 4 Jun 2017 hello every body I need help to upload the source code from F930GOT-BWD-C HMI I am using GT Designer 3 and PC connector (RS-232C connector), D-sub, 9-pin thanks Share this post Link to post Share on other sites
Posted 5 Jun 2017 GT designer 3 is not capable of communicating with the F900 series as the F900 series has been obsolete for about 10-12 years now. You will need GT designer classic which luckily is included in the CD for GT designer 3. You will need to install this software (I can't remember the exact name, but do a search of the CD for "classic", I think it's GT2 Classic). I'm not sure if you're planning on using this HMI or just retrieve the program, but I would recommend you upgrade. As mentioned before this HMI is obsolete and was replaced by the GT1030 series which is either now obsolete or will be shortly and replaced by the GT2104 series. You would use GT designer 3 for either the GT1030 or GT2104. Share this post Link to post Share on other sites
