HenryDara
VB "Dim" not compiling
3 posts in this topic
The following is VB code for "On Open" of a display.
For some reason I get an error - "Error 2612: Invalid function or missing := in assignment expression [Script, SpurStatus_On_Open: Text]" (referring to the line that starts with "Dim")
In a duplicate project the same exact code is happy as a clam, but for some reason this project wont validate, and the terms do not highlight correctly in the VB editor.
Dim i <---should be green, but its black
For i = 0 TO 5
View.AssignIndirect HL_ManualPB.Element("CMD_L").index(i).Name,  H_ManualPB.Element("CMD_L").index(i).Name
View.AssignIndirect HL_ManualPB.Element("CMD_R").index(i).Name,  H_ManualPB.Element("CMD_R").index(i).Name
Next <---should be green, but its black
Without ALL the code, who knows. Maybe you defined "I" somewhere else.
A variable that is declared at module level, outside https://hitthegrade.com/ any procedure, is a member variable or field. Member variables are in scope throughout their class, structure, or module. A variable that is declared at procedure level is a local variable. Local variables are in scope only within their procedure or block.
