Posted 26 May 2017 (edited) Hello. This is my first post and I hope someone has a solution. I have a program calculating Gal/sec adding to a running total and have up to the end. Using REAL I can accumulate up to 16,777,216 (2^24) and using DINT up to 2,147,483,648 (2^31), but I need to have my registers continue past these limits. I've read through many topics here and have tried the Rockwell Knowledge Base but can't seem to find a solution that truly works. I have gone so far as to transfer the DINT to a string, cut the string into pieces and reassemble them in an Odometer type concatenation. If anyone has a suggestion, I would appreciate it. I know I'm not the only one with this problem. PS & BTW - I'm using Studio 5000 v24 with a 1769 L33ER Edited 26 May 2017 by JRH Share this post Link to post Share on other sites
Posted 26 May 2017 You are pretty much on the right track. If it were me I would have two DINTs, LowDint and HighDint. LowDint increments as normal, then have a GEQ source A being the LowDint and source B being 1,000,000,000 to add one to the to the HighDint and set the LowDint back to 0. Then convert both to strings and Concatenate them into a string that represents the flow total. Share this post Link to post Share on other sites
Posted 26 May 2017 Thanks TWC, but I don't think it will work for me. I am adding the readout of a flowmeter which has a decimal (i.e. 14.82 +- var). I tried a quick test with a GEQ of 1000 then reset, [and two running totals synced to see if the reset would lose any continuity] but since the total didn't hit 1000 exactly (was 998.xx then 1012.xx), the reset would lose that bit that was over the 1000 right before the reset. I am also trying to put the excess over 1000 into a Remainder and add the remainder back into the total. I get the two totals closer to each other but not completely synced. The error will compound over time (regulatory reporting issues abound). Share this post Link to post Share on other sites
Posted 26 May 2017 I didn't catch the decimal. Probably switching the low tag to floating and lowering the trigger will work, but how many decimals to the left and the right will you need? Share this post Link to post Share on other sites
Posted 26 May 2017 I will probably be needing 4 or 5 decimal places. Share this post Link to post Share on other sites
Posted 26 May 2017 Have you tried a Double Precision Float. It will get a higher value range and greater precision. I know that the logix controllers support the type. Share this post Link to post Share on other sites
Posted 26 May 2017 2 hours ago, JRH said: I will probably be needing 4 or 5 decimal places. Its hard to imagine needing 4 or 5 decimal places with an accumulated value that runs into the billions. 1 person likes this Share this post Link to post Share on other sites
Posted 27 May 2017 agreed. besides, flow rate (gal/sec) and total (gal) are two different things... while decimal places may make sense in flow rate, they are pointless in displaying total volume that goes into billions. i would suggest to consider fixed point math instead of floating point. then you cam easily do what TW suggested and keep "decimal places" Share this post Link to post Share on other sites
Posted 30 May 2017 As for losing the part that's over your reset point, subtract instead of reset: GRT LowDint 1000 SUB LowDint 1000 LowDint Add HighDint 1 HighDint Share this post Link to post Share on other sites
