Posted 8 May 2017 HELLO ALL I HAVE PROBLEM CX SUPERVISOR RUN TIME WORKING WHEN I OPEN RUN TIME AFTER 2 OR 3 HOUR IT WILL STOP AND COMMUNICATION CUT FROM PLC I USE OMRON PLC AND MT NETWORK SETTING IN PLC ETHERNET (FINS/TCP) I GIVE ONE IP ADDRESS 172.17.0.85 AFTER CUT COMMUNICATION THIS MESSAGE WILL COMING MY PC - COULD NOT WRITE TO PROJECT FILE. THE DISK IS FULL,WRITE-PROTECTED OR HAS BEEN REMOVED FROM THE DRIVER ple told me some one how to salve this problem Share this post Link to post Share on other sites
Posted 15 Oct 2017 Hi, Recommend you check your Windows Event Log to see if any process has crashed. If so then raise with developers on myOMRON.com Regards BB Share this post Link to post Share on other sites
