chrisb4748
Indirect Indexing
8 posts in this topic
Hi,
I am trying to indirectly index 1 D register, into 999 ZR registers.
i.e.
I have 999 dollies that are going through the factory. Each with an individual carrier ID.
I want to use 1 D register to pick up that carrier ID and enter it into the corresponding ZR Register.
If Carrier ID is 123 I want D990 to enter that into ZR60123 Or Carrier ID is 598 I want D990 and enter that into ZR60598.
How should I go about this?
Many Thanks
Depends on your programming software.
In direct mitsubishi code this would be.
MOV K123 Z0
MOV D.... ZR6000Z0  (ZR6000 + 123).
However it is also possible to write an address into a Registers and then use @ to indicate it is an indirect address.
If you use structured programming you should make an array for ZR6000 ......
Then it would be something like:
Mov K123 Mypointer
Mov MyValue MyArray[MyPointer]
I am using GX Works2.
Is there another way of doing this? The way you have described "K...." will be changing so I couldn't use a constant.
My client has a new RFID system installed and is wanting to be able to select the different dollies through out the factory.
And in reference to the "Mypointer" could you explain further into that as I'm not 100% sure.
I personally find structured text is much easier (and clearer) to use when dealing with arrays/indexes
With “Dollies” declared as a zero based array of 1000 int’s starting at ZR60000  [0..999]
and “CarrierID” declared as an Int
and D990 has a value 888
When “CarrierID” has a value of 0 then the statement...
Dollies[CarrierID] := D990
would put the value of 888 into ZR60000
When “CarrierID” has a value of 123 then the statement...
would put the value of 888 into ZR60123
When “CarrierID” has a value of  990 then the statement...
would put the value of 888 into ZR60990
K was just an example to make it clear this could alos be a word
The My pointer is the same as the 123 in the previous example. It's just the word containing the needed offset
I have never written in structured text, but appears to be the easiest way to go about this.
Could you give me some advice on doing this?
Thanks
Structured is indeed very flexible but maybe my explanation was not so good so here is an actual example.
MyDataword is the value you want to move
Carrier ID is only the offset (123)
MyArray starts at ZR60000
But like @chrisb4748 already mentioned Structured text is also a good way of doing this.
Edited by Gambit
