Posted 1 Apr 2017 hello Friends how can I Connect FX5U by direct RJ45 to download program on it and the type of cable should be cross cable or straight cable Thanks . Share this post Link to post Share on other sites
Posted 1 Apr 2017 Hello Mazen_abs, At least you need the GX-Works or IQ Works software to download. I'm not sure if the FX5U has a build in webserver. In the FX3 series there is. Just type in the IP number of the FX5U in your internet explorer tot test. To connect make sure your laptopp/PC networkcard is in the same IP range and subnetmask as the FX5U. Modern laptops from Dell and HP can handle straight and cross RJ45 cables. If you are not sure just put a simple ethernetswitch in between the computer and the PLC. Than you have straight cable connections only. Best regards, Theo V. Share this post Link to post Share on other sites
Posted 2 Apr 2017 For more information download Melsec IQ-F FX5 Series User's Manual [Ethernet Communication] http://lmgtfy.com/?q=fx5+ethernet Share this post Link to post Share on other sites
