asteroidehk
UDS1100 to SLC 5/04?
2 posts in this topic
Hello Friends
I have gotten a UDS1100 to connect a 5/04 PLC to Ethernet through serial port.
I have set the IP address in the UDS1100, but I can get the serial port working.
When I connect my PC to the PLC (serial port) the RS232 led in the CPU blinks, When I connect the UDS1100, it does not blinks.
Should I see the PLC in the RSLinx Ethernet Driver?
Is it posible to connect thought Ethernet the PC-UDS1100-5/04?
I need this to get some tags with Kepserver.
Thanks in advance.
By UDS-1100, I presume you mean an Lantronix device.
Understand that you need to configure both the Ethernet and the Serial sides of the UDS-1100.  On the serial side, you need to match the settings of the DF1 serial port of the SLC.
That said, I quickly did a search of DF1 on Lantronix website and found plenty of documents with details for setting up their various IAP-series devices.
Lastly, the Serial Port (DF1 protocol) probably has a differnet pinout from most simple RS-232 devices, hence the specific serial cable.  Try putting that between the UDS-1100 and the DF1 port on the SLC.
