RaulAPM
Convert time
4 posts in this topic
Hello.
this is my firs post
is possible to convert the elapsed time of timer to real or int
i need to make some math operation with the elapsed time
thanks
Use TimeToSec to convert time to UINT.
Then use **_TO_*** (Integer-to-Real Number Conversion Group).
1 person likes this
Or you could use the 'Timer' function(100 ms timer) this function has the time as UINT.
Hello,
you can create a function (ST language) in Sysmac with this name => INT_TO_TIME
code :
// Input is an INT and return in TIME
          NanoSecToTime(In:=INT_TO_LINT(In:= Input) * LINT#1000000);
After you can use an INT on a TON :
// TON_Test : TON;          Start_Test : BOOL;          iValue_Test : INT;
          TON_Test (IN := Start_Test,     PT := INT_TO_TIME(iValue_Test));
David
