amadkey
Test Connection error
4 posts in this topic
Hi all,
I have problem to connect my Pc to PLC.
when i find cpu using build in ethernet, the PLC was found.
IMG_20170222_090929(2).thumb.jpg.dcace96
Then i choose the PLC cpu, and try to test the connection an error show.
58acef5aebdf7_IMG_20170222_085050(2).thu
how to solve this problem?
It's a good thing to write what you did to solve your problem. That way, if others are reading the forums and searching for a solution to a similar problem, they can see your answer/solution.
the problem is the IP address in my PC is 192.168.1.82. I have two PLC with address 192.168.1.100 and 100.10.100.20 respectively.
My PC IP address 192.168.1.82 can read the PLC 192.168.1.100 without any error. But the problem is to read PLC 100.10.100.10
So, i have to configure my PC local area network adaptor using advance setting and put another IP address to reach the PLC 100.10.100.20.
Edited by amadkey
