SABET
cannot connect to fx2n plc
4 posts in this topic
Hi
I have 2 fx2n 64MR/MT plc I can connect to one of them without any problem but other one the PROG_E LED is flashing and I cannot connect to it for programming and dowanload my backup to it , its error is aboat cpu type or cable.
the battery of this cpu disconnected for 10 days.
pay attention that I can connect to other CPU same as it(I said at first).
thanks every boady
I have paid attention and my conclusion is it is faulty and needs replacing.
Try putting a new battery in it. When PROG_E flashes it is a battery problem. Then reset the PLC and try the Connection Test if you are using GX works or transfer Setup -> Connection Test if you are using GX Developer. If that says it's connected try to download you back-up from your PC to the PLC again.  I'm 90% sure the battery is dead and that's why it's in fault.
If it still flashes after replacing the battery, it's a programming issue. Maybe wrong type of CPU set in the Software or something.
