Posted 16 Jan 2017 CAN SOMEONE PLEASE SUGGEST ME ONE OF THE BEST ONLINE LADDER LOGIC SIMULATOR OR SIMULATOR SOFTWARE FOR PRACTICING AND DEVELOPING LADDER LOGIC SKILLS.?? Share this post Link to post Share on other sites
Posted 22 Feb 2017 I don't know if it is the best or not, but whatever soft-plc out there should be OK: CodeSys, TwinCAT... TwinCAT is free, it installs the runtime in your PC and meanwhile you are using windows and "version 3" or "version 2 with a 32 bits OS" you'll be able to simulate everything, in fact you will have a software based PLC running in your computer. Notice that except Allen Bradley and Siemens, mostly all the others are using a Codesys flavor. Anyway if you stay standard then everything should be the same. Hope this helps. Share this post Link to post Share on other sites
Posted 23 Feb 2017 Joan, actually there are many vendors that do not use Codesys, including Mitsubishi, Omron, Siemens, Idec, AB, Siemens. Share this post Link to post Share on other sites
