Mortoch
Mortoch
How to perform INT and DINT functions in an FX3u using GXDeveloper? Such as creating a int or dint and then using the individual aspects of the instance to perform a task. IE. I need to turn on 8 outputs depending upon a number input from a HMI such as 200 which will be turned into a binary which will turn on the outputs depending on whether the individual bit of the binary is 1 or 0. AB RS5000 makes it simple, I am trying to get a handle on the Mitsubishi and any help would be appreciated.
IN and DINT are not needed in GX Developer only in GX IEC Developer and GX Works structured mode
if i am understanding you correctly you want to use a word or double word to turn on or off outputs ?
I think All you want to do is MOV D0 K2Y0. This will put the binary value of D0 to Y0-Y7.
If you want that the value of D0 is the out then look at the ENCO DECO instrcutions
Edited by Gambit
2 people like this
yes TheUns exactly. Thank you Gambit I will try that.
Definite success. That worked as advertised, you  have my most sincere thanks.
