Lost Al
FX-ENET-P502 Modbus TCP interface nformation
Hi, I have just purchased a FX-ENET-P502 for my FX3GE and need a little assistance to get started. I have trawled the WWW to find configuration, connection details, message structure or any other tutorials and clues. I would be grateful for direction to any material to help get started. Thank you
FX-ENET-P502 never heard of it.  Sure it works with FX3GE?
Didn’t think you could use an FX3U-ENET-P502 module with FX3GE PLC because the PLC has already got onboard Ethernet. Just like you can’t put two ENET modules on the same PLC (well this is what Mitsubishi told us when we asked a few years ago).
I would be interested if anybody knows different.
The FX ENET module should work on FX3GE. It's easy to check via the online configurator
https://us.mitsubishielectric.com/fa/en/flash/fx/FXSelectionSystem.swf
The P502 version is the same as a normal ENET module accept that you can select use port 502 which is needed for modbus connections.
The module itself doesn't support the protocol you'll need the modbus FB's
Edited by Gambit
