markyspicer
FX3U For GXworks2 and WinCC Flex
3 posts in this topic
Hi,
Is there any way in order to monitor both PLC(GXworks2) and HMI(WinCCFlex) using only 1 port from the PLC(FX3U)?
I have tried it but I'm not able to communicate the other application(one at a time only).
Thanks!
How is the HMI connected to the PLC, RS422 CPU port serial ?
I use a software called "Serial-IP" when I have a E1000 screen connected (RS422 serial) to a Mitsubishi CPU.
Transparent mode must be correctly set up in the E1000 HMI to make it work.
Don't know if you can do it with Siemens HMI.
Hi Bryll!
It is connected directly via usb-rs232 cable by Mitsubishi. I don't know if this "Serial-IP" has the same thing in Siemens.
