Posted 10 Nov 2016 Hey guys, I want to select an HMI which has Good library including pie charts, Bargraphs, datalogger, trends. Also im able to connect hmi with laser printer. Hmi which has good internal memory and touch. Please can you tell me which make HMI is best for this. Thanks Share this post Link to post Share on other sites
Posted 10 Nov 2016 There are many that fit that description but I would go with the GOT2000 series. Then you also have some nice extra features as database communication and smartphone/tablet connections Share this post Link to post Share on other sites
Posted 10 Nov 2016 Currently i am using weintek HMI but that has not good library as i want. Is the GOT2000 series has good datalogger function Share this post Link to post Share on other sites
Posted 10 Nov 2016 Yes you can save as csv and copy it to a usb drive when you connect one to the terminal Share this post Link to post Share on other sites
Posted 10 Nov 2016 OK ... Its sound nice. I will go with GOT series. And one more can i connect with laser printer if i want . Share this post Link to post Share on other sites
Posted 23 Nov 2016 Yes if it's a serial printer or a PictBridge compatible printer Share this post Link to post Share on other sites
Posted 26 Nov 2016 WinCC Flexible Advanced 2008 SP3 or TIA Portal WinCC v13 Share this post Link to post Share on other sites
Posted 29 Oct 2017 HI I can Provide you HMI for your need you have to give details of your printer, how much data storage you require, data storage on time base?? then how much time Share this post Link to post Share on other sites
