Stuart_Wales
GX Works 2.... Convert SFC to Ladder
30 posts in this topic
2 hours ago, Stuart_Wales said:
How do we register under the task manager?
Under "Program Setting" you should have one of the execution types where all the POU's are registered. Right click on a task and click "Open Task Setting" to open a table of POU's registered. Insert the POU name you want to register somewhere in the list, where it should be. Remember that the list is executed in order from 1 to ...
2 people like this
As always, thank you mate! I'll try and let you know how we get on!
PLC Parameters, Program tab
Cheers lads. It seems that original programmer has split a section labelled 'POU', which looks to me as if it isn't under the 'scanned program' and 'MAIN' section. When checking parameters, program..... only 'MAIN' was selected.
So I have dragged 'OEE' from the 'POU' and into 'MAIN' and assume this will be resolution. I will test it Monday.
(I will obviously then delete the 'OEE' from the 'POU' tree) ertwe.thumb.png.601e5e6849c8de3f9dcddb42
Thanks lads.
Please DO NOT delete the OEE from POU-pool!!
The Taskmanager control the execution of the programs in the POU.
You still have to make a compile, so it all has to be Black and not red as in your screen.
/Dariusch
