pradeep chauhan
how to set up timer in st
13 posts in this topic
Hello all
I m new in st programming in omron
I want to use timer in st please help me regarding this
If you look at the help file for a function / instruction that you would like to use, you can see the ST layout for that item.  See below:
weOop1iiyQq9QAAAABJRU5ErkJggg==
Just copy that text and paste it into your structured text and modify.  You could end up with something like this:
ADj8cpihs4uOAAAAAElFTkSuQmCC
Variables:
PlzuHnjBjyfaiNaiIiIyrb4n47Duk4dNGnSVLQUH
1 person likes this
I just noticed that I gave you an answer for Sysmac Studio.  Please ignore the above answer....
For CX-Programmer, type ahead works in the structured text environment.  The type ahead will show you what each field is expecting:
wdWIekzgaoe2wAAAABJRU5ErkJggg==
So, you end up with something like this:
we4ZRiv5wy6rgAAAABJRU5ErkJggg==
1 person likes this
Variables:
May you help me change this ladder into ST, please
5baa6230680c1_STtimerExample.jpg.98b508d
Make sure to declare all of the variables that you are using in the structured text block as I have shown above.  I declared I00 as a global since your code did that.
1 person likes this
Thank you so much Wash.
When I want to use another TON with different PT , do I need to declare another  function block with different instance name or can I use that FB above , only need to change the value of T , and the condition of IN
You would need to declare another instance of the FB.  You could use the TIMER function however.  Functions do not require instances.
1 person likes this
Thank you Walsh again. By the way, this problem is not related to the topic; but do you know how to clear an event in event history.
Hi Michael Walsh,
I had a question about using timers or counters in structured text. I did declare the timer in the external section. I did try it declaring it in internal. I always end up getting the same error. I suppose you will be able to help me with my question. Please see the attached screenshot of my program and errors.
code :TIMX(A, TimerNumber, 500);
Declaration:TimerNumber    TIMER                            INTERNAL     0    0
ERROR: Symbol 'TimerNumber' is the invalid data type(TIMER or COUNTER) in the SFC/ST program.
Thanks
JOEL
I am not having any issues.  If you post your code here(.cxp file), I can look at it to see if I can tell what is wrong.
TIMXSt.jpg.b8b359fbadc846147f138327188c4
10 hours ago, joelsimon15 said:
Hi Michael Walsh,
Thanks
JOEL
What is the model number of the PLC you are using? CJ2M, CP1L, CP1E............................
Structured Text timers or Counters can ONLY be used with CS/CJ series CPU units version 4.0 or later, or with CJ2-Series CPU units.
Edited by BITS N BYTES
More Info
Good point.... @BITS N BYTES
