Posted 29 Sep 2016 The topic is based on "How to configure a PCM module in GE PLC". One new query in PCM. To configure this PCM Module some procedure is to be followed in CMD prompt. Initially once ''READY'' line displayed. Query to this topic is if ''READY'' line repeats below persistently in CMD prompt, then solution is ______???? Share this post Link to post Share on other sites
Posted 2 Oct 2016 I don't completely understand your question. What software are you using to communicate with the PCM module? What command are you entering at the CMD prompt? What are you trying to accomplish? Configuration of the PCM module is generally done in the PLC's hardware configuration. Share this post Link to post Share on other sites
Posted 3 Oct 2016 The links here will help you to sort this out. https://ge-ip.force.com/communities/CC_Knowledge?q=90-30%20PCM However I strongly suggest that you update to an RX3i and forget about using a PCM module as they are no longer available if you have any problems with it in the future. Share this post Link to post Share on other sites
