Posted 28 Sep 2016 I have been using Mitsubishi PLCs for the last 17 years and to be honest whenever I need to shift data I generally use an Arduino. But I have existing PLCs that each need to be connected to a PLC running Biometric Readers. The handshake between the PC in a box (running the biometric readers) and the PLC (running an access control turnstile) will be 8 bit ASCII code via RS232 connection. I am struggling to find any working examples of code to run an RS232 BD card on an FX3G PLC, I have set up an FTDI RS232 UART and I can see data coming in from an Arduino but I can't get the FX3g to send any data via RS232. I can't even get the PLC to communicate. Unfortunately the tech support offered here in the UK is awful. Any help would be appreciated. Regards Julian Share this post Link to post Share on other sites
Posted 28 Sep 2016 Have you got\read this manual? http://www.mitsubishielectric.com/dl/fa/document/manual/plc_fx/jy997d16901/jy997d16901n.pdf If so what would you like to know? 1 person likes this Share this post Link to post Share on other sites
Posted 28 Sep 2016 Thank You Gambit, that's a big help, I will have a look through. Will let you know how I get on. Regards Share this post Link to post Share on other sites
