Chickenkiller91
plc startup ob? run program only 1 time at start
3 posts in this topic
Hello!
Is it possible to run a program only 1 time when i turn on the plc?
In siemens it was ob 100 or soemthing like that, that program only runs one cycle at startup of plc.
I want to make sure some bits are off at startup to be in safe position
Thank you for your help!.
Yes - use the first scan flag for setting anything up.
You can use the P_First_Cycle flag to turn the bits off directly as Bob suggested.
You can also use the TKON(820) & TKOF(821) instructions to turn on and off an entire task at any time you want. I often create an initialize task that runs once at startup and turns itself off with the TKOF instruction when complete. This works best if you assign the startup task as cyclic task 00 with Operation Start checked (default) and include a TKOF instruction as the last rung of the task immediately before the END(001) instruction.
