TemperedEnterprises
RSLogix 5000 Code Generation using C#
5 posts in this topic
            CsvFileDescription d = new CsvFileDescription { SeparatorChar = ',', FirstLineHasColumnNames = true };
            CsvContext cc = new CsvContext();
            List<Pump> Pumps = new List<Pump>(cc.Read<Pump>(@"c:\tmp\pumps.csv", d));
            RSLogix5000Content c = RSLogix5000Content.Load(@"C:\tmp\test.l5x");
            Tag PAck = new Tag() { Name = "AlarmsProgAck", DataType = "BOOL", Description = new Description { TypedValue = "All Alarms Program Ack" } };
            Tag PRes = new Tag() { Name = "AlarmsProgRes", DataType = "BOOL", Description = new Description { TypedValue = "All Alarms Program Reset" } };
            Tag PEn = new Tag() { Name = "AlarmsProgEn", DataType = "BOOL", Description = new Description { TypedValue = "All Alarms Program Enable" } };
            Tag PDis = new Tag() { Name = "AlarmsProgDis", DataType = "BOOL", Description = new Description { TypedValue = "All Alarms Program Disable" } };
            c.Controller.Tags.Tag.Add(PAck);
            c.Controller.Tags.Tag.Add(PRes);
            c.Controller.Tags.Tag.Add(PEn);
            c.Controller.Tags.Tag.Add(PDis);
            int x = 1;
            foreach (Pump p in Pumps)
                String InterlockBuilder = "";
                if ((p.Interlocks ?? "").Contains(','))
                    string[] Interlocks = p.Interlocks.Trim().Split(',');
                    foreach (string interlock in Interlocks)
                        InterlockBuilder += "XIC(" + interlock + "Running)";
                Tag PStart = new Tag() { Name = p.Name + "Start", DataType = "BOOL", Description = new Description { TypedValue = p.Description + " Start Command" } };
                Tag PStop = new Tag() { Name = p.Name + "Stop", DataType = "BOOL", Description = new Description { TypedValue = p.Description + " Stop Command" } };
                Tag PRunA = new Tag() { Name = p.Name + "Run", TagType = "Alias", AliasFor = p.StartOutput, Description = new Description { TypedValue = p.Description + " Run Output" } };
                Tag PRunningA = new Tag() { Name = p.Name + "Running", TagType = "Alias", AliasFor = p.RunInput, Description = new Description { TypedValue = p.Description + " Running Input" } };
                Tag PAlarmD = new Tag() { Name = p.Name + "Alarm", DataType = "ALARM_DIGITAL", Description = new Description { TypedValue = p.Description + " Start Alarm" } };
                Rung r = new Rung();
                r.Number = x++;
                r.Comment = new Comment { TypedValue = "Pump Logic Code for " + p.Description };
                r.Text = new Text { TypedValue = "[" + InterlockBuilder + "[XIC(" + p.Name + "Run)XIO(" + p.Name + "Stop),XIC(" + p.Name + "Start)]OTE(" + p.Name + "Run),XIC(" + p.Name + "Run)XIO(" + p.Name + "Running)ALMD(" + PAlarmD.Name + "," + PAck.Name + "," + PRes.Name + "," + PDis.Name + "," + PEn.Name + ")];" };
                Routine PumpRoutine = new Routine { Name = p.Name, Type = "RLL" };
                PumpRoutine.RLLContent = new RLLContent();
                PumpRoutine.RLLContent.Rung.Add(r);
                c.Controller.Programs.Program[0].Routines.Routine.Add(PumpRoutine);
                c.Controller.Programs.Program[0].Routines.Routine[0].RLLContent.Rung.Add(new Rung { Number = x, Text = new Text { TypedValue = "JSR(" + p.Name + ",0);" } });
                c.Controller.Tags.Tag.Add(PStart);
                c.Controller.Tags.Tag.Add(PStop);
                c.Controller.Tags.Tag.Add(PRunA);
                c.Controller.Tags.Tag.Add(PRunningA);
                c.Controller.Tags.Tag.Add(PAlarmD);
            c.Save("c:\\tmp\\testout.l5x");
Here is the code that generates the ladder logic.
wuld you mind sharing more info on this topic. How you are doing it e.t.c, e.t.c
This is a really nice application. Only I see that you are using your own defined package "TemperedEnterprises.Tools.Rockwell.PLC" - is this possible to share this on this forum or on GitHub. This package is actually what does the construction of the XML files.
