professor_jonny
GATED TIMER FUNCTION ?
3 posts in this topic
Hi
I'm programming a cp1l plc and I'm wondering if there is a better way of accomplishing a gated timer.
I'm wanting to dump water into a tub but if the tub becomes fill it will pause the timer and continue on when the tub empty's a bit.
Currently I'm using a counter with a 1sec clock pulse into its input it is just a complicated way of doing it I'm just wondering if someone has a better idea as this plc can't use function blocks?
the problem arises that the timers need to be forced to be completed to stop them operating on powerup
Edited by professor_jonny
Omron has a Totalizing Timer, TTIM(087) for BCD values and TTIMX(555) for Decimal values.
I personally find nothing wrong with using clock pulses and counters. When I need to control time, I usually increment (++) a DM location using clock pulses. So there are a few solutions but the canned solution is the Totalizing Timer.
1 person likes this
