slasher
Using CX-Drive Inquiry
4 posts in this topic
Good Day,
i would like to ask some assistance.....
how to covnert the parameter of Smart Step Servo Drive
R7D-AP02H to R7D-BP02H
using CX-Drive software....
Edited by slasher
There is no way to do it automatically.  You will have to do it manually.
It should not take too long.
... i have some difficulties...
OLD Parameter
R7D-AP setting
PN202-  Gear Ratio(Numerator) - Value = 4
PN203- Gear Ratio(Denamenator) - Value = 1
R7D-BP
PN46 - Gear Ratio Numerator 1
PN47 - Gear Ratio Numerator 2
PN4A - Gear Ratio Numerator Exponent
PN4B - Gear Ratio Denamenator
how can i supposed to apply the this parameter?
If SW6 on the old drive is ON, then the gear ratio parameters are used, if it is OFF, then Switches 4 and 5 determine the command resolution (see the manual).
If SW6 is ON:
Old servo:  To make the servo motor turn 1 time, you need to input pulses to make the encoder move 8000 pulses (encoder resolution x 4 - quadrature format).  The gear ratio in Pn202 and Pn203 will be multiplied by the input pulses to determine how far to move the motor.  So, with a ratio of 4:1, if you input 2000 pulses to the drive, the motor will move 1 revolution.
2000 * 4/1 = 8000 = 1 rev.
New servo:
Unfortunately, the new servo is a 2500 pulse per rev encoder, so it will take 10000 pulses to move one revolution.  Therefore, you need a 5:1 gear ratio.
Therefore you would need to set Pn46 to 5 and Pn4b to 1.
2000 * 5/1 = 10000 = 1 rev.
